Testing MrMC 3.4.1
Re: Testing MrMC 3.4.1
Post by cosmoxl »
davilla wrote: 23 Jan 2018, 13:33 3.4.1 beta is live on Google Play, anyone else than me try it ?
what? What's the change for Shield?
edit: already installed. black glass nova skin is the only change, right?
cosmoxl wrote: 23 Jan 2018, 17:17
Yes, new skin and minor nits. Biggest change is regarding the distro. We now have to use apk extension files as we blew over the 100MB limit with GooglePlay on the main apk.
Itzme1234
Post by Itzme1234 »
TvOS, opacity, my 3rd party remote, Expert is unchecked... I'd prefer skip back (left) always be 10 seconds. Right now I think it's doing 20 secs? Ideally without having to hit pause, but I not sure that's possible. I honestly am too bad at math to figure out what it's exponentially doing in FF now (30, 60, 10?)but it's confusing me.
Should be (and I see) exactly 10, 30, 1min, etc for defaults. This can be changed in settings and best to wait until we push again as this areas has been changed.
It's possible that you are seeing a double send of the button, there was an issue with IR remotes that triggered a double send.
Post by timstephens24 »
Itzme1234 wrote: 23 Jan 2018, 19:48 TvOS, opacity, my 3rd party remote, Expert is unchecked... I'd prefer skip back (left) always be 10 seconds. Right now I think it's doing 20 secs? Ideally without having to hit pause, but I not sure that's possible. I honestly am too bad at math to figure out what it's exponentially doing in FF now (30, 60, 10?)but it's confusing me.
davilla wrote: 23 Jan 2018, 20:02 Should be (and I see) exactly 10, 30, 1min, etc for defaults. This can be changed in settings and best to wait until we push again as this areas has been changed.
Honestly I think this is an area that needs the defaults changed. Set it to a set 10 seconds forward and 10 seconds backwards, or something similar (I have it at 30 seconds forward and 10 seconds back). Most new people aren't going to want a 30 second jump, then a 1 minute jump, then a 3 minute jump, etc etc, because it's not just a set time and makes subsequent clicks irksome. tvOS is default a set 10 seconds forward and 10 seconds back. It's great that MrMC is customizable, but most don't know what that is so default should be tvOS default (10 seconds forward and 10 seconds backward).
I agree, defaults for seek jumps needs to be sanitized for novice users. Once they realize it can be changed, then they can set it to what they desire. A linear 10 sec jump forward/backwards would match the native player and then no surprises.
Itzme1234
Post by Itzme1234 »
Then a good default is 10 back / 30 forward, because this is the way alot of DVRs work. I think its the way MrMc worked before all this, too.
Ted377
Post by Ted377 »
davilla wrote: 23 Jan 2018, 16:47 Pretty quiet here :) Just a note, we have over 100 users in testflight, but we only get a handful actually posting here. I smell a purge coming.
Nothing to post ;) If I discover a problem, I will inform you immediately. MrMC runs almost non stop with me, because I enjoy my TV program about it :D
timstephens24 wrote: 22 Jan 2018, 22:16 1. Tapping should bring up the progress bar without pausing or anything (like the native player)
2. Click and hold would be nice to fast forward/rewind (like the native player)
3. Double click would be nice to skip forward/skip back (not like the native player; enhanced functionality but sensitivity would need to tweaked to keep from accidentally doing it instead of just trying to jump twice)
4. Turn subtitles on and off with triple tapping with the progress bar up (like the native player)
You get 1, 2, and 4.
3 is a little redundant as click left/right will do seeks.
Post by cosmoxl »
davilla wrote: 24 Jan 2018, 03:33
:ugeek:
