Content of MrMC Log
15:51:32.879 T:6176026624 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:51:32.879 T:6176026624 NOTICE: -----------------------------------------------------------------------
15:51:32.879 T:6176026624 NOTICE: Starting MrMC (3.9-3 Git:2019-09-25-b956598-dirty). Platform: TVOS ARM64 64-bit
15:51:32.879 T:6176026624 NOTICE: Using Release MrMC x64 build
15:51:32.879 T:6176026624 NOTICE: MrMC compiled Sep 24 2019 by Clang 11.0.0 (clang-1100.0.33.8) for TVOS ARM64 64-bit version 11.2.0 (110200)
15:51:32.880 T:6176026624 NOTICE: Running on Apple Inc. AppleTV6,2 with TVOS 13.0, kernel: Darwin ARM 64-bit version 19.0.0
15:51:32.880 T:6176026624 NOTICE: Host CPU: arm64 v8, 3 cores available
15:51:32.880 T:6176026624 NOTICE: ARM Features: Neon enabled
15:51:32.880 T:6176026624 NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/4DD2FF1F-37A8-499D-BCAD-2DBB60FE76C5/MrMC.app/AppData/AppHome
15:51:32.880 T:6176026624 NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/4DD2FF1F-37A8-499D-BCAD-2DBB60FE76C5/MrMC.app/AppData/AppHome
15:51:32.880 T:6176026624 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Containers/Data/Application/9E0C07E3-86FD-4F26-A35A-BA895A262A77/Library/Caches/home/userdata
15:51:32.880 T:6176026624 NOTICE: special://home/ is mapped to: /var/mobile/Containers/Data/Application/9E0C07E3-86FD-4F26-A35A-BA895A262A77/Library/Caches/home
15:51:32.880 T:6176026624 NOTICE: special://temp/ is mapped to: /private/var/mobile/Containers/Data/Application/9E0C07E3-86FD-4F26-A35A-BA895A262A77/tmp/temp
15:51:32.880 T:6176026624 NOTICE: special://logs/ is mapped to: /var/mobile/Containers/Data/Application/9E0C07E3-86FD-4F26-A35A-BA895A262A77/Library/Caches/logs/
15:51:32.880 T:6176026624 NOTICE: special://frameworks/ is mapped to: /private/var/containers/Bundle/Application/4DD2FF1F-37A8-499D-BCAD-2DBB60FE76C5/MrMC.app/Frameworks
15:51:32.880 T:6176026624 NOTICE: The executable running is: /private/var/containers/Bundle/Application/4DD2FF1F-37A8-499D-BCAD-2DBB60FE76C5/MrMC.app/MrMC
15:51:32.880 T:6176026624 NOTICE: Local hostname: Media-Room
15:51:32.880 T:6176026624 NOTICE: Log File is located: special://logs/mrmc.log
15:51:32.881 T:6176026624 NOTICE: -----------------------------------------------------------------------
15:51:32.911 T:6176026624 NOTICE: load settings...
15:51:32.920 T:6176026624 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
15:51:32.920 T:6176026624 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
15:51:32.921 T:6176026624 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
15:51:32.924 T:6176026624 WARNING: CSetting: duplicate <update> definition for "lookandfeel.soundskin"
15:51:32.924 T:6176026624 ERROR: CSetting: missing <control> tag of "videoscreen.vsync"
15:51:32.924 T:6176026624 WARNING: CSettingGroup: unable to read setting "videoscreen.vsync"
15:51:32.926 T:6176026624 NOTICE: Found 1 Lists of Devices
15:51:32.926 T:6176026624 NOTICE: Enumerated DARWINIOS devices:
15:51:32.926 T:6176026624 NOTICE: Device 1
15:51:32.926 T:6176026624 NOTICE: m_deviceName : default
15:51:32.926 T:6176026624 NOTICE: m_displayName : Default
15:51:32.926 T:6176026624 NOTICE: m_displayNameExtra:
15:51:32.926 T:6176026624 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:51:32.926 T:6176026624 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
15:51:32.926 T:6176026624 NOTICE: m_sampleRates : 44100,48000
15:51:32.926 T:6176026624 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT
15:51:32.926 T:6176026624 NOTICE: m_streamTypes : No passthrough capabilities
15:51:33.007 T:6176026624 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:51:33.007 T:6176026624 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:51:33.007 T:6176026624 NOTICE: Default DVD Player: dvdplayer
15:51:33.007 T:6176026624 NOTICE: Default Video Player: dvdplayer
15:51:33.007 T:6176026624 NOTICE: Default Audio Player: paplayer
15:51:33.007 T:6176026624 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:51:33.007 T:6176026624 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:51:33.007 T:6176026624 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:51:33.007 T:6176026624 ERROR: CMediaSourceSettings: error loading special://masterprofile/sources.xml: Line 0, Failed to open file
15:51:33.007 T:6176026624 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:51:33.008 T:6176026624 NOTICE: Loaded playercorefactory configuration
15:51:33.008 T:6176026624 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:51:33.008 T:6176026624 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:51:33.023 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
15:51:33.023 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
15:51:33.023 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.042667
15:51:33.045 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
15:51:33.046 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
15:51:33.047 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
15:51:33.047 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
15:51:33.047 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
15:51:33.048 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.042667
15:51:33.048 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
15:51:33.048 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 32
15:51:33.217 T:6176026624 NOTICE: Running database version Addons20
15:51:33.280 T:6176026624 NOTICE: Found possible resolution for display 0 with 3840 x 2160
15:51:33.280 T:6176026624 NOTICE: Checking resolution 16
15:51:33.280 T:6176026624 NOTICE: GL_VENDOR = Apple Inc.
15:51:33.280 T:6176026624 NOTICE: GL_RENDERER = Apple A10X GPU
15:51:33.280 T:6176026624 NOTICE: GL_VERSION = OpenGL ES 3.0 Metal - 66.6
15:51:33.280 T:6176026624 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
15:51:33.280 T:6176026624 NOTICE: GL_EXTENSIONS = GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
15:51:33.363 T:6178893824 NOTICE: Running database version Addons20
15:51:33.363 T:6178893824 NOTICE: Running database version ViewModes6
15:51:33.364 T:6178893824 NOTICE: Running database version Textures13
15:51:33.369 T:6178893824 NOTICE: Running database version MyMusic60
15:51:33.372 T:6178893824 NOTICE: Running database version MyVideos107
15:51:33.373 T:6178893824 NOTICE: Running database version TV29
15:51:33.374 T:6178893824 NOTICE: Running database version Epg11
15:51:33.488 T:6176026624 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:51:33.491 T:6176026624 ERROR: JSONRPC: Missing implementation for method "VideoLibrary.GetInProgressTvShows"
15:51:33.502 T:6176026624 ERROR: Control 9000 in window 10000 has been asked to focus, but it can't
15:51:33.503 T:6176026624 NOTICE: initialize done
15:51:33.503 T:6176026624 NOTICE: Running the application...
15:51:33.503 T:6176026624 NOTICE: starting zeroconf publishing
15:51:33.503 T:6176026624 NOTICE: WebServer: Started the webserver
15:51:33.503 T:6176026624 NOTICE: starting upnp client
15:51:33.519 T:6178893824 NOTICE: PVRManager - starting up
15:51:35.149 T:6177173504 NOTICE: Found 1 Lists of Devices
15:51:35.149 T:6177173504 NOTICE: Enumerated DARWINIOS devices:
15:51:35.149 T:6177173504 NOTICE: Device 1
15:51:35.149 T:6177173504 NOTICE: m_deviceName : default
15:51:35.149 T:6177173504 NOTICE: m_displayName : Default
15:51:35.149 T:6177173504 NOTICE: m_displayNameExtra:
15:51:35.149 T:6177173504 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:51:35.150 T:6177173504 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
15:51:35.150 T:6177173504 NOTICE: m_sampleRates : 44100,48000
15:51:35.150 T:6177173504 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT
15:51:35.150 T:6177173504 NOTICE: m_streamTypes : No passthrough capabilities
15:51:35.164 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
15:51:35.164 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
15:51:35.164 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.042667
15:51:35.206 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
15:51:35.206 T:6177746944 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
15:51:35.207 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
15:51:35.207 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
15:51:35.207 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
15:51:35.208 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.042667
15:51:35.208 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
15:51:35.208 T:6177746944 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 32
15:51:35.615 T:6184628224 NOTICE: CPlexServices: Server found via plex.tv NUC
15:51:36.158 T:6176026624 NOTICE: PVRManager - stopping
15:51:37.071 T:6176026624 ERROR: Control 9000 in window 10000 has been asked to focus, but it can't
15:51:38.688 T:6184628224 ERROR: Previous line repeats 2 times.
15:51:38.689 T:6184628224 NOTICE: CPlexServices: Server found via plex.tv WW_Plex
