emby server 4.2.0.40 is not found
sdmaged99
Re: emby server 4.2.0.40 is not found
How do we obtain this new beta on Nvidia Shield TV?
Imhotep
I have installed the beta now and it went exactly for a short momnet.
Now the emby server is again not found.
19:52:51.147 T:6161199104 DEBUG: found key /userdata/profiles.xml
19:52:51.148 T:6161199104 DEBUG: Previous line repeats 1 times.
19:52:51.148 T:6161199104 DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
19:52:51.149 T:6161199104 DEBUG: found key /userdata/guisettings.xml
19:52:51.158 T:6161199104 DEBUG: Previous line repeats 1 times.
19:52:51.158 T:6161199104 DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 31027 to 6269
19:52:51.158 T:6161199104 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:52:51.261 T:6161199104 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
19:52:51.263 T:6161199104 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:52:51.263 T:6161199104 DEBUG: ------ Window Init (Settings.xml) ------
19:52:56.434 T:6161199104 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:52:56.555 T:6161199104 DEBUG: ------ Window Deinit (Settings.xml) ------
19:52:56.555 T:6161199104 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:52:56.555 T:6161199104 DEBUG: ------ Window Init (Home.xml) ------
19:52:56.558 T:6161199104 DEBUG: CGUIWindowHome::SetupServices() - serverType(mrmc) , serverUUID(mrmc)
19:52:56.565 T:6161199104 DEBUG: CMultiPathDirectory::GetDirectory(multipath://multipath%3a%2f%2fspecial%253a%252f%252fprofile%252fplaylists%252fmusic%2fspecial%253a%252f%252fprofile%252fplaylists%252fmixed%2f/multipath%3a%2f%2fspecial%253a%252f%252fprofile%252fplaylists%252fvideo%2fspecial%253a%252f%252fprofile%252fplaylists%252fmixed%2f/)
19:52:56.565 T:6161199104 DEBUG: Getting Directory (multipath://special%3a%2f%2fprofile%2fplaylists%2fmusic/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
19:52:56.565 T:6161199104 DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3a%2f%2fprofile%2fplaylists%2fmusic/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
19:52:56.565 T:6161199104 DEBUG: Getting Directory (special://profile/playlists/music)
19:52:56.565 T:6161199104 DEBUG: Getting Directory (special://profile/playlists/mixed)
19:52:56.565 T:6161199104 DEBUG: CMultiPathDirectory::MergeItems, items = 0
19:52:56.565 T:6161199104 DEBUG: Getting Directory (multipath://special%3a%2f%2fprofile%2fplaylists%2fvideo/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
19:52:56.565 T:6161199104 DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3a%2f%2fprofile%2fplaylists%2fvideo/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
19:52:56.565 T:6161199104 DEBUG: Getting Directory (special://profile/playlists/video)
19:52:56.566 T:6161199104 DEBUG: CMultiPathDirectory::MergeItems, items = 0
19:52:56.566 T:6161199104 DEBUG: Previous line repeats 1 times.
19:52:56.566 T:6161199104 DEBUG: CGUIWindowHome::SetupStaticHomeButtons()
19:52:56.566 T:6158331904 DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
19:52:56.568 T:6158331904 DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
19:52:59.558 T:6161199104 DEBUG: ------ Window Init (DialogSelect.xml) ------
19:53:01.835 T:6161199104 DEBUG: ------ Window Deinit (DialogSelect.xml) ------
19:53:03.123 T:6161199104 DEBUG: Activating window ID: 10004
19:53:03.255 T:6161199104 DEBUG: ------ Window Deinit (Home.xml) ------
19:53:03.255 T:6161199104 DEBUG: ------ Window Init (Settings.xml) ------
19:53:07.425 T:6161199104 DEBUG: Activating window ID: 10018
19:53:07.555 T:6161199104 DEBUG: ------ Window Deinit (Settings.xml) ------
19:53:07.555 T:6161199104 DEBUG: ------ Window Init (SettingsCategory.xml) ------
19:53:16.675 T:6161199104 DEBUG: ------ Window Init (DialogNetworkSetup.xml) ------
19:53:21.336 T:6161199104 DEBUG: ------ Window Deinit (DialogNetworkSetup.xml) ------
19:53:21.337 T:6161199104 DEBUG: Using proxy mrmc:8080, type 0
19:53:21.337 T:6161199104 DEBUG: CurlFile::Open(0x16f3c5910) http://192.168.10.3:8096/emby/Users/AuthenticateByName
19:53:21.337 T:6161199104 INFO: easy_aquire - Created session to http://192.168.10.3
19:53:21.345 T:6161199104 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve proxy name(5)
19:53:21.345 T:6161199104 ERROR: CEmbyServices:AuthenticateByName failed 0,
19:53:21.345 T:6161199104 ERROR: CEmbyServices: Could not get authToken via manual sign-in
19:53:21.347 T:6161199104 DEBUG: found key /userdata/profiles.xml
19:53:21.347 T:6161199104 DEBUG: Previous line repeats 1 times.
19:53:21.347 T:6161199104 DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
19:53:21.347 T:6161199104 DEBUG: found key /userdata/guisettings.xml
19:53:21.350 T:6161199104 DEBUG: Previous line repeats 1 times.
19:53:21.350 T:6161199104 DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 31027 to 6269
19:53:21.356 T:6161199104 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
19:53:25.219 T:6161199104 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------- amet
Any specific reason you have proxy setup and enabled? That seems to be causing the issues
Imhotep
ups, that was an accident
. After I decoded it, it still didn't work, he didn't find a server.
When I deleted the app and installed it again it worked again (BUG?).
sdmaged99
Any news on the new release of MrMC to fix this issue with Emby? The beta version i'm using to get around the issue is a tad buggy so i've had to move back onto Plex until the new release
aaaMMMaaa
It seemed a new version was released yesterday? 3.9.0?
Running MrMC (latest) on Atv4K-TvOS (latest)
Correct, 3.9.0 but due to the issues with Nvidia only Apple TV / iOS for now.
