do you have motion smoothing enabled on your TV?satfeed1 wrote: 19 Nov 2019, 14:14 Here is picture with Yadif2x. You can see blocking on the left side, but there is no many motion on the picture.
The CPU usage percent is around 210%.
TV de-interlacing option (ATV4 4K)?
Re: TV de-interlacing option (ATV4 4K)?
satfeed1
I have old LCD television without tricky functions
Do you have ATV4K too?
yessatfeed1 wrote: 19 Nov 2019, 16:28I have old LCD television without tricky functions![]()
satfeed1
Here is a short sample: https://we.tl/t-bWOg1NeU3d
Please try with Yadif2x and tell me your experience!
yadif2x works for me if I set it as the default deinterlacer for all media and start the file with yadif2x being used.satfeed1 wrote: 20 Nov 2019, 11:21 Here is a short sample: https://we.tl/t-bWOg1NeU3d
That said, it still doesn't look great at the red shorts green grass interface. Lots of flashing.
yadif looks a little better maybe but you do lose the framerate.
even bob inverse has some flashing of red here and there but looks plenty good in my opinion.
satfeed1
I need to work Yadif2x, because it is best quality method, but if I use Yadifx2 the Audio/Video synchron is very bad and video is stutters. This is main problem for me.
18:28:47.089 T:6115291136 DEBUG: Previous line repeats 1 times.
18:28:47.089 T:6115291136 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
18:28:47.090 T:6115291136 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
18:28:47.116 T:6115291136 DEBUG: OutputPicture - interlaced: yes
18:28:47.132 T:6115291136 DEBUG: Previous line repeats 1 times.
18:28:47.132 T:6115291136 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
18:28:47.132 T:6115291136 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
Here is another longer sample: https://we.tl/t-JTSS6phRVJ
Problems are same and dropped frames with Yadif2x.
I hope development team can help me.
yadif comes with ffmpeg. perhaps something could be fixed by updating the version of ffmpeg they are using. but I know nothing about that.satfeed1 wrote: 20 Nov 2019, 17:59 I need to work Yadif2x, because it is best quality method, but if I use Yadifx2 the Audio/Video synchron is very bad and video is stutters. This is main problem for me.
yeah, there is bad sync problem when using yadif2x. but watching that longer file I really have no complaints when using bob inverse. To my eye it looks sharp with no deinterlacing errors.
satfeed1
You may be right about FFmpeg. Yadif2x method is not working properly with H.264 High 4:2:2 profile.
Which version of FFmpeg does MrMC use?
