Just tested ... no, that doesn't work for me either. But it can definitely be fixed.
TV Infobar Topic is solved
- Ted377
Re: TV Infobar
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Re: TV Infobar
Can anyone explain please?
I can’t skip using iptv so it has to be a blind fix
- Montoya
Re: TV Infobar
Good old DVBLink and, in my opinion not so good replacement, TVMosaic (regarding config. options), can pause and skip BW/FW IPTV, by using a standard or configurable time-shift buffer.amet wrote: 07 May 2020, 19:52 Can anyone explain please?
TVHeadend has that too, correct ?
So maybe you could load a free IPTV list from the internet in TVHeadend, for testing purposes.
- Ted377
Re: TV Infobar
I have a little thing that I haven't noticed yet.
Currently you have shown the from/to time as: 16:00 : 16:45.
Can you change it with a minus? Ex. 16:00 - 16:45
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Re: TV Infobar
hopefully all is ok now, skip and time format changed
- Ted377
Re: TV Infobar
Will test it later and report
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
- Ted377
Re: TV Infobar
Everything works as it should
Thanks for the quick fix
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
kamil66
Re: TV Infobar
Hello since the last updat We no longer have the extra bar at the top To put the subtitles For the tv section Thanks again for the good work
- Montoya
Re: TV Infobar
If you are using 3.9.7 TestFlight version, check "Scenario E" from this post below, to navigate to Top Info Bar, to change subtitle settings during Live TV:kamil66 wrote: 25 May 2020, 18:13 Hello since the last updat We no longer have the extra bar at the top To put the subtitles For the tv section Thanks again for the good work
https://forum.mrmc.tv/viewtopic.php?p=28169#p28169
