No but it's on the list to add to Plex client. Emby client has this ability and users seem to like it so we are going to being it into Plex client.barong wrote: 26 Nov 2017, 06:15 Thanks. I’ll do some testing.
Unrelated, but is there any way to hide certain libraries imported using Plex?
Testing MrMC 3.3.0
Re: Testing MrMC 3.3.0
Two seconds seems to be my sweet spot.davilla wrote: 26 Nov 2017, 01:05Sure, it can be lowered. I'm at three seconds and seems like it could go lower for my setup.barong wrote: 25 Nov 2017, 23:29 Frame rate and HDR/SDR switching looks to be working fine.
Out of interest you have the default delay set to 4 seconds, is this the recommended delay or can it be lowered without causing issues?
funkydan2
A while back I posted about the TV menu not showing. It's very intermittent, and so I hadn't seen it happen for a while, but it happened again yesterday and I managed to capture the log for it.
Also - with the latest testflight the main interface overflows my TV. I went to the Video settings and corrected the overscan - but I'd not had to do that before.
(20171126-9b5c348)
fixed xcode build regarding app submittion
This is release candidate. We are waiting review.
Tons of ERROR: SQL: [Epg11.db] The database disk image is malformed.funkydan2 wrote: 26 Nov 2017, 23:42 A while back I posted about the TV menu not showing. It's very intermittent, and so I hadn't seen it happen for a while, but it happened again yesterday and I managed to capture the log for it.
Wow, that was fast. Less than one day for both iOS and tvOS.davilla wrote: 26 Nov 2017, 23:48 (20171126-9b5c348)
- Ted377
For next TestFlight...
In the Plex settings you can disable the following feature.
”Include in dashboard“
(Include content from this library in On Deck, Recently Added, and global slideshows.)
This setting is unfortunately not adopted by MrMC.
Is it possible to consider this in the next TestFlight?
Best save any request for when the next testflight cranks up, less it get lostTed377 wrote: 28 Nov 2017, 00:16 For next TestFlight...
smeagol152
This means that is Approved? Because I cannot see version 3.3 available in App Store. By the way, are you going to push this version in Github?
Thanks!!!
