TV Infobar Topic is solved
Any Opacity skin issues go here
Ted377
Re: TV Infobar
Post by Ted377 »
viewtopic.php?p=27858#p27858
Only when i switch the channel.
No channel icon in the infobar.
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
Ted377
Re: TV Infobar
Post by Ted377 »
Oooooooookay ... then let me address a few little things :D
1. could you draw the dividing lines a little longer? (see my suggestions)
2. is it feasible to adjust the icons (status etc.) in the right field? (see my suggestions) should I send you something?
3. is the text from now in normal and from next in bold.
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Ted377
Re: TV Infobar
Post by Ted377 »
I can currently open the infobar with select.
That‘s very good.
With menu I get to the next selection (stop, recording, etc.).
With a swipe down I get the description.
It's a bit tricky but you get used to it quickly.
When switching the channels, unfortunately I only see the timeline and not the infobar.
Unfortunately, the time for automatic hiding cannot be changed until now.
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Re: TV Infobar
Ted377 wrote: 14 Apr 2020, 21:08 Oooooooookay ... then let me address a few little things :D
1. longer? higher? :)
2. you can send me icons, you have my email... just note that all video badges are needed, all audio badges are needed all channel layouts(there is 8 of em) and resolution frame, we add "16:9" in that frame
3. its possible.. I'll check
Re: TV Infobar
Ted377 wrote: 14 Apr 2020, 21:21 ...
a bit busy with other things, I'll check that... info bar should come up when switching channels
auto hide is now hardcoded to 5 sec, I'll see if there is a way to make it use the system setting... I am sure there is :)
Montoya
Re: TV Infobar
Post by Montoya »
amet wrote: 21 Apr 2020, 18:55
Info bar doesn't come up when switching channels now in TF 200419.950.
amet wrote: 21 Apr 2020, 18:55 auto hide is now hardcoded to 5 sec, I'll see if there is a way to make it use the system setting... I am sure there is :)
Using "Auto hide OSD to NEVER" now, overcoming Info Bar hardcoded auto hide timing. So an auto hide time setting, for Info Bar is appreciated.
Regarding logic:
Can pause button on Siri remote, also bring up Info Bar and show indicator/button on Info Bar that program is paused ?
Kudos @Amet for restarting work on Info Bar and Ted377 for reminding Amet ;)
Re: TV Infobar
please look out for the next TestFlight(next day or so), should have most of this fixed now.
let me know if there is more
Ted377
Re: TV Infobar
Post by Ted377 »
Sorry for the late reply.
I've been a bit busy in the last few days and will take care of the other things as soon as possible.
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Ted377
Re: TV Infobar
Post by Ted377 »
amet wrote: 24 Apr 2020, 22:06 please look out for the next TestFlight(next day or so), should have most of this fixed now.
First of all, the adjustments have become very good.
Thanks for that.
The next problem is auto hide.
The displays remain here until they are closed with the menu / back button.
I do not know if this is wanted.
I will dare to run the badges tomorrow and send you the first drafts as soon as possible.
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Re: TV Infobar
Info bar is there until you close it , video osd should close after set time in settings.
If we want both on a timer, let me know
