Blu-ray main title not in simplified menu
BanRay
Re: Blu-ray main title not in simplified menu
Post by BanRay »
I used X-plore to browse the internal storage of the Shield and found the log in a MrMC temp folder 8-)
Here it is: https://pastebin.com/Z6FHWB0p
I truly hope you find something. If you need more information, or additional testing, please let me know.
BillyBudapest
Post by BillyBudapest »
Sounds like the same thing I observed and reported long ago that HDMV menus don't show for 1080p Blu-Rays in MrMc the way they do in Kodi. This points to some difference in the implementation of libbluray.
BanRay
Post by BanRay »
Thanks for your insight. However:
-I have some 2160p movies that show a main movie title
-I have some 2160p movies that don't show a main movie title
-I have some 1080p movies that show a main movie title
-I have some 1080p movies that don't show a main movie title
So as far as I'm concerned there is some other root cause.
And I repeat: the movies that don't show a main movie title using MrMC on the Shield, do show a main movie title using MrMC on the Apple TV 4K.
lots of "Connection timed out" errors.
BanRay
Post by BanRay »
If a movie/menu works, it always works. If a movie/menu does not work, it never works. The root cause is not the network. It is something else.
I can unhook the Shield, and hook up the ATV4K. Then play the exact same movie using MrMC. Then you can compare the logs?
BanRay
Post by BanRay »
Here are a number of logs. I did tests using MrMC on the Shield and the same tests (same network connection, same movie on the same location) using MrMC on the ATV4K. Here are the results:
Shield Not OK - Aladdin 1080p: https://pastebin.com/Z6FHWB0p
Shield Not OK - Fantastic Beasts 2160p: https://pastebin.com/cgCSkwpM
Shield OK - Indiana Jones 1080p: https://pastebin.com/Yt0BxKVF
Shield OK - Thor 2160p: https://pastebin.com/sv7ncsqd
ATV4K OK - Aladdin 1080p: https://pastebin.com/SBgY9L2v
ATV4K OK - Fantastic Beasts 2160p: https://pastebin.com/ELGxiCna
ATV4K OK - Indiana Jones 1080p: https://pastebin.com/0kQZWKAx
ATV4K OK - Thor 2160p: https://pastebin.com/FVEb3XBc
BanRay
Post by BanRay »
@davilla @amet
Is there something else I can do? Other logs?
We are looking into it
BanRay
Post by BanRay »
Thx! I hope you can fix it. Then I will buy MrMC also for my Shield :D
please try libdsm (smb1) or libsmb2 (smb2) instead of libsmbclient.
