Music section is missing in main menu
Gunjahx
Re: Music section is missing in main menu
Post by Gunjahx »
Yes, same issue in all skins
If it’s missing in opacity/Ariana that means that your music library doesn’t exist, how is it setup? Sources are setup for music and are added into the library?
Let’s see the music source setup screen please
dnicks2525
Post by dnicks2525 »
amet wrote: 02 May 2019, 19:37 If it’s missing in opacity/Ariana that means that your music library doesn’t exist, how is it setup? Sources are setup for music and are added into the library?
Yeah, I had the same issue. Then I realized it doesn't show the option to add music to the home screen until you add the source.
Gunjahx
Post by Gunjahx »
Where can I find this settings? The library should be there because the Section was already shown months ago. If you tell me how to find the section with the sources I will take a picture.
Media sources -> music sources
Select the source, long press select and edit... go through the setup and verify that it asks you to add media to Library.
If media is added to library, music button will show on screen
Gunjahx
Post by Gunjahx »
There is no „media sources“ section. Only e.g. in videos I can add a source as folder and to the library.
namwollem
Post by namwollem »
Gunjahx wrote: 05 May 2019, 13:13 There is no „media sources“ section. Only e.g. in videos I can add a source as folder and to the library.
I found this as well - you'll need to revert to the standard (default) skin, THEN on the main page you will find "Media Sources" - where you can add your music source. When you go back to your normal skin, the MUSIC section will be present!
Gunjahx
Post by Gunjahx »
You are right, when I change the skin I can see the media sources section. When I select music I can see my two already added sources, but they are still not shown. Deleting and re-adding does not solve the problem. Adding them to home screen only shows them in this skin.
