TV shows are not being added to library
TrevorDanger
Re: TV shows are not being added to library
So, been a couple of weeks. Any chance the updated version (whenever Amazon allows it) will fix this, or am I forced to keep using Plex?
The C Man
New to this Forum so apologies if I get this wrong.
Had a similar problem with one library. Cured by changing the name of the problem one so I could recognise it and then created a new library. Once I checked it was adding new files I deleted the old one. Sorry it only a workaround.
Incidentally, my film libraries are organised by years to make them easier to find and create smaller directories.
Now for the update. One server would not Scan new files until I went into Properties for the folder and cancelled "Read only" for everything.
