TV de-interlacing option (ATV4 4K)?
Re: TV de-interlacing option (ATV4 4K)?
Post by cosmoxl »
davilla wrote: 15 Dec 2017, 14:55
vlaves wrote: 15 Dec 2017, 09:12
davilla wrote: 03 Dec 2017, 20:20yes it does.
You mean 2x yadif on 1080i h264 streams? :shock: :D
Yes, the Apple TV 4K has the ponies to handle it.
:o :P
Boulder
Post by Boulder »
cosmoxl wrote: 15 Dec 2017, 23:46
:o :P
Is it really true when also upsizing to 4K? I was just testing a 1080i music video clip which didn't look at all smooth with YADIFx2 enabled, I had to choose the other YADIF setting to make it look normal..
Post by cosmoxl »
Boulder wrote: 25 Mar 2019, 19:42
:o :P
Yes, it works well on some content. On other content it doesn't. :)
satfeed1
Post by satfeed1 »
Hello davilla and everyone!
I'm trying to play 1080i50 H.264 streams(video: cca. 20mbit/s)
Yadiff2x is the best mode for me when video is H.264 4:2:0 top first, but picture is freezing when video is H.264 high4:2:2 (YUV 4:2:2-top first). Do you have any idea? How to solve this problem? Inverse BOB mode is always working, but it is not the best quality method to deinterlace sports events.
Post by cosmoxl »
satfeed1 wrote: 16 Nov 2019, 22:34 Hello davilla and everyone!
I would guess it's maxing out the CPU with the high.
satfeed1
Post by satfeed1 »
cosmoxl wrote: 16 Nov 2019, 23:25
What is the maximum value? I see 200-240 percent CPU load.
Post by cosmoxl »
satfeed1 wrote: 18 Nov 2019, 10:01
that's normal cpu usage with yadif then. it could be that that type of deinterlacing just isn't working well with that content. have you tried yadif and not yadif2x?
satfeed1
Post by satfeed1 »
Yadif-half gives me 25frames/sec insted of 50frames/sec, but it is working with no problem. Unfortunately 25fps not so good for sporting events. I need 50fps with Yadif2x. Tomorrow I will upload a short video sample for you. What is the maximum CPU load?
Post by cosmoxl »
satfeed1 wrote: 18 Nov 2019, 18:46 Yadif-half gives me 25frames/sec insted of 50frames/sec, but it is working with no problem. Unfortunately 25fps not so good for sporting events. I need 50fps with Yadif2x. Tomorrow I will upload a short video sample for you. What is the maximum CPU load?
actually, I think the maximum is something like 400 or 600. I forget, does it have 4 cores or 6 cores?
I'm just another user so I'm only giving advice. If you upload that'll be to the devs who may also have some answers of their own.
satfeed1
Post by satfeed1 »
Here is picture with Yadif2x. You can see blocking on the left side, but there is no many motion on the picture.
The CPU usage percent is around 210%.
